Readers' choice "Products of the year 2022"96 products, your decision!
96 products make up the list of nominees for this year's "Products of the Year 2022" readers' poll! Now your opinion counts: Which are the most innovative and useful products?
Hy-Line - Holographic input via infrared:
A new terminal for holographic input from Hy-Line works completely without touch: the device is operated simply by marking virtual buttons in the air. The holographic input system can be divided into two individual parts: the generation of a holographic image and the detection of a touch event.
The holographic image is created by directing the content of an image source - in this case a display - through a special holographic plate. In addition to the angular deflection, a convergent bundling of the rays takes place there, which creates a virtual image floating freely in space. During integration, the optical laws for the beam path and reflections must be observed. As the brightness decreases due to the conversion, a display with a high luminance of approx. 1,000 cd/m² must be used. An infrared touch sensor is mounted below the virtual image. Its beam path is interrupted when the image is 'touched'. The interruption is evaluated as a touch event: as a single touch, multi-touch or as a gesture.
