Readers' choice "Products of the year 2022"96 products, your decision!
96 products make up the list of nominees for this year's "Products of the Year 2022" readers' poll! Now your opinion counts: Which are the most innovative and useful products?
8 of 9
Products of the Year 2022 - Nominated in the Robotics category: Artiminds
© Artiminds
Artiminds - No-code software solution 'ArtiMinds Robot Programming Suite':
Handling dimensionally unstable and sensitive ribbon cables is difficult due to their low rigidity and requires a great deal of dexterity, meaning that assembly is still mainly carried out manually. To increase the efficiency of this process, ArtiMinds Robotics has developed a robot-based automation approach. The sensor-adaptive application is planned, simulated and programmed using the no-code software solution 'ArtiMinds Robot Programming Suite' (RPS). A vacuum gripper is mounted on the robot arm to pick up the ribbon cable from a defined position. The software's 'spike search' module automatically compensates for tolerances during the insertion process: To find the correct insertion position, the robot performs a force-controlled search movement and attempts to insert the cable into the socket. As soon as a defined insertion depth is registered by the force-torque sensor, the robot knows that it has found the socket and inserts the dimensionally stable component at this point.
Directly to the tuning
8 of 9
