Readers' choice "Products of the year 2022"96 products, your decision!
96 products make up the list of nominees for this year's "Products of the Year 2022" readers' poll! Now your opinion counts: Which are the most innovative and useful products?
5 of 9
Products of the Year 2022 - Nominated in the Image Processing category: IDS
© IDS
IDS - Ultra-compact 3D entry-level camera 'Ensenso S10':
The 'Ensenso S' 3D camera from IDS is particularly suitable for 3D applications that require easy-to-integrate industrial-grade camera technology. The Ensenso S10 in an IP65/67-protected die-cast zinc housing generates 3D data using laser point triangulation, supported by artificial intelligence. It is equipped with a 1.6 MP Sony sensor and works with a laser-based 3D process. A narrow-band infrared laser projector generates a high-contrast dot pattern, even on objects with difficult surfaces or in dimly lit environments.
The laser point triangulation is accelerated by a neural network and enables a reliable assignment of the recorded pattern points to the fixed coded positions of the projection. This results in geometrically precise 3D data with high depth accuracy. With object distances of 50 cm, the maximum deviation is 0.6 mm. With full projector power, up to 20 point clouds per second are achieved. The camera has a 60° field of view and a working range of 0.5 to 3 m.
Directly to the tuning
5 of 9
