Readers' choice "Products of the year 2022"96 products, your decision!
96 products make up the list of nominees for this year's "Products of the Year 2022" readers' poll! Now your opinion counts: Which are the most innovative and useful products?
Wago - Mini terminal blocks 'Topjob S':
Wago is expanding its terminal block portfolio to include a mini version with a nominal cross-section of 2.5 mm², supplementing the 1 mm² version already available. The compact Topjob S mini terminal blocks are suitable for wiring work in confined connection boxes, for example for motors, pumps or devices in control cabinets. Despite its compact design, the 2.5 mm² variant (maximum 4 mm² without wire end ferrule) can be used for applications up to 24 A (maximum 32 A without wire end ferrule) and 800 V (IEC)/600 V (UL). In both versions (1 mm² and 2.5 mm²), the mini terminal blocks offer various mounting options and can be used flexibly: they can be mounted on a 15 mm x 5 mm mounting rail or on a mounting plate with snap-in feet or mounting flanges.
The terminal blocks are equipped with either an intuitive push-button or an actuation opening - both actuation types also allow direct plugging with push-in connection. Both the 1 mm² and 2.5 mm² mini terminal blocks are approved in accordance with CCA, UL, CSA, IECEx and ATEX, AEX.
