Readers' choice "Products of the year 2022"96 products, your decision!
96 products make up the list of nominees for this year's "Products of the Year 2022" readers' poll! Now your opinion counts: Which are the most innovative and useful products?
Turck - Fast RFID I/O module for EtherCAT TBEC interface:
With the TBEC family, Turck is expanding its range of robust and compact RFID solutions with fast interfaces for Ethercat networks. The 'TBEC' module in a fully encapsulated plastic housing is designed in protection class IP67/IP69K and can be used in the extended temperature range from -40 to +70 °C. The Ethercat RFID module allows parallel operation of HF and UHF read/write heads. Like all Ethernet multiprotocol devices from Turck, the 'TBEC' also supports the HF continuous bus mode, by means of which up to 32 bus-capable HF read/write heads can be connected to each of the four RFID channels. In applications with many read or write positions
positions, this reduces wiring effort, costs and commissioning times.
Sensors, lamps or other actuators can be connected to the eight universal DXP I/Os. All connections are designed as 5-pin plug connections in M12, the power supply (L-coded) is provided via M12 power technology.
