Readers' choice "Products of the year 2022"96 products, your decision!
96 products make up the list of nominees for this year's "Products of the Year 2022" readers' poll! Now your opinion counts: Which are the most innovative and useful products?
Halstrup-Walcher - Software modules for 'PSD' direct drives with IO-Link:
Halstrup-Walcher has added software modules to its PSD direct drives with IO-Link, allowing the drives to be controlled faster and more flexibly or used more effectively for applications such as tool changers or conveyor belts. With the 'Set changeover' software module, users can directly activate up to four different parameter sets via two bits in the process data. These four sets each contain 13 parameter values that influence the drive behavior (e.g. set speed, acceleration, drive current).
With the 'Set speed in process data' function, any set speed can be transferred, while one of four speeds previously defined in the parameter sets is selected when the set is switched. The 'Modulo function' offers advantages if drives are always to be operated in the same direction of rotation, as can be useful for tool changers or conveyor belts. In modulo mode, the travel path is not limited. Users can define a specific travel path as a so-called modulo width in the software by specifying a lower and an upper modulo position as end positions.
