Eplan at the Hannover Messe
Alexandra Hose,
AR app connects switch cabinet with digital twin
Eplan presents new functions of the "eView AR" app: By overlaying a real control cabinet with its digital twin, the virtual world is linked to the real world.
The Eplan app "eView AR" allows split-screen view of circuit diagram and digital twin in augmented reality
© Eplan
In Hanover, Eplan is presenting the extended "eView AR" app, which makes electrical engineering documentation for enclosures available via augmented reality - directly on the enclosure during operation.
App guides service technicians through the process
With the extended app, which should be available from May 2024, service technicians will be able to overlay the real switch cabinet with its digital twin using a tablet or smartphone. In short: the technician has digital access to every single component directly at the control cabinet.
For example, a motor protection switch needs to be replaced. The service technician is visually guided by AR highlighting and knows exactly where the component is positioned in the enclosure - even if the enclosure door is closed. This allows components to be located quickly, especially in large enclosures or rows of enclosures. The service technician can then use the digital twin to obtain all the necessary information, such as the wiring diagram and the circuit diagram page with the motor starter combination. This also eliminates the need to search through potentially extensive paper documentation. It guides the technician or maintenance employee quickly through their maintenance activities.
Restoring changes to the project
If a contactor needs to be replaced, for example, the digital twin not only shows the manufacturer's specifications for the component, but also refers to its electrical engineering documentation. The technician notes the replacement of this component via redlining or greenlining and the engineering department can simply implement the changes on all pages of the electrotechnical documentation. If there are cross-references to other circuit diagram pages, these are also automatically updated in engineering. The best thing is that collaboration in Eplan is bidirectional - from service to engineering and vice versa.
QR code ensures clear assignment
A QR code generated in Eplan links the documentation of the control cabinet with the real cabinet in operation. The project is stored in the Eplan Cloud and is therefore clearly assigned. The 3D view of the enclosure structure is superimposed on the mounting plate or the enclosure itself using the AR function. The digital twin from Eplan Pro Panel is placed 1:1 on the components inside the enclosure - simply using a tablet or smartphone. With the AR app, the project documentation is visualized in 2D as a circuit diagram or in 3D as a virtual image of the enclosure.
Quick error analysis via split screen
Quick localization of relevant components in the enclosure through visual overlay
© Eplan
Split-screen technology allows the circuit diagram and AR model of the cabinet to be displayed side by side if required. This allows the fault to be traced quickly in the event of a machine downtime. The fact that equipment lists, parts lists, cable overviews and other evaluations such as topologies can be accessed via a cross-reference is another practical advantage. After all, there is no need to leaf through the documentation. The entire documentation can be viewed at any time and from anywhere in the world via the Eplan Cloud. This also facilitates collaboration across departmental boundaries. This speeds up and simplifies the service and maintenance process. What's more, the electrical engineering documentation is always accessible and always up to date. This also makes future maintenance or service cases easier.
Digital Twins
With real-time data against disasters
A digital twin is more than just a two- or three-dimensional digital copy. It combines precise data with intelligent analysis and solves complex challenges. With locations in Paderborn and other cities, Eviden relies on the combination of artificial...
SAS
More precise digital twins in production
SAS, provider of solutions for data and AI, is launching a new generation of digital twins on the market. The combination of SAS Analytics and 3D visualization in real time ensures photorealistic simulations in production.
IFS
Transformation projects are very popular
IFS announces the results of a recent study, according to which the manufacturing industry is at a critical turning point. Although manufacturing companies are aware of the need for digital transformation, a lack of strategies and an oversupply of...
