Product presentationsNew energy management products
In a product picture series, Computer&AUTOMATION presents the latest energy management products - from digital load management systems to active energy meters.
VX25 Ri4Power 185 mm is the system technology for the production of safe low-voltage switchgear or power distribution boards with type approval in accordance with IEC 61439. It can be easily integrated into the 'VX25' enclosure system from Rittal. Standardized installation kits for every enclosure width simplify installation, particularly thanks to the drill-free design. The other system components of both systems can be easily integrated using the installation kits. According to the manufacturer, the 'VX25 Ri4Power 185 mm' system meets the highest safety requirements thanks to its encapsulated design and the use of components for operator-independent disconnection and switching. Thanks to tested adapter technology, even compact circuit-breakers can be easily installed. The 'VX25' is also prepared for the 'VX25 Ri4Power ISV' modules for the installation of distribution boards in industrial building technology. Rittal provides special installation kits for easy installation of the expansion modules in the enclosure. The assembly complies with the IEC 61439 standard and is documented with a type certificate.
