Product presentationsNew energy management products
In a product picture series, Computer&AUTOMATION presents the latest energy management products - from digital load management systems to active energy meters.
6 of 9
Power PM-IP67A200 from MTM
© MTM Power
The primary switched power PM-IP67A200 from MTM has an IP67 degree of protection and has been specially designed for the electrical supply of control systems, sensors and actuators in the field directly at the application to be supplied. The direct use of the power supply modules as a "plug and play" solution on site is made possible by the connection via special 7/8-inch plug connectors and the thermoselective vacuum potting developed by MTM Power. The device series has 24 V single and dual outputs and is certified in accordance with the UL 60 950-1 and UL 508 standards. The compact power supplies with AC (90 to 264 V(AC)) and DC wide-range input (100 to 300 V(DC)) are designed for worldwide use under extreme environmental conditions and enable users to solve various power supply tasks in indoor and outdoor 'on-machine' applications. The devices with 24 V output voltage are optionally equipped with a variable current limiter and are therefore able to supply 1.5 times the nominal output power for short periods. The dual output voltages are galvanically isolated from each other with 500 V(AC) isolation voltage and independently regulated, both output voltages are Limited Power Sources according to EN 60 950-1 and UL 1310, NEC class 2. The devices comply with protection class 1 and fulfill the Low Voltage Directive as well as the current EMC standards for CE conformity.
6 of 9
