Pulse
3-phase power supply unit with Ethercat interface
'Fiepos FPT500' from Puls is a 3-phase power supply unit with 600 W output power, four electronically protected outputs and a fully integrated Ethercat connection for direct access to power supply functions and numerous measured values.
© Pulse
The integration of Puls field power supplies into industrial networks such as Ethercat simplifies commissioning and optimized operation of the complete system. This enables central configuration and monitoring of the power supply parameters, such as the input and output voltage and current values, the tripping characteristics of the integrated electronic fuses and the adjustable alarm limits. The power supply unit and system status can be monitored in real time using the measured values recorded, and immediate action can be taken in the event of deviations from the norm. No additional gateways are required to connect the 'FPT500.245-018-103ETC' 3-phase power supply unit to the Ethercat control system.
Pulse
Acquisition of Wiferion
Puls takes over Wiferon and thus all existing contracts, trademark rights and patents of the wireless charging specialist. In the medium term, users will benefit from Puls' global production capacities.
LEM
Two new coreless high-current sensors
The direct-imaging 'OLCI' (Open-Loop Coreless Integral) sensors from LEM measure direct currents from 2 to 42 kA without surge current limitation and have a large opening for measuring high currents on large busbars with a bandwidth of up to 1 MHz.
