Rittal
Support arm with larger radius
Rittal offers height-adjustable support arm systems from the CP series with a longer support profile for loads of up to 15 kg in order to adjust operating terminals precisely to the height of the operator and their area of activity.
Height-adjustable support arm systems from the CP series from Rittal
© Rittal
Support arm systems are used where operating devices or terminals for machine operation need to be flexibly positioned or moved over an obstacle when moving from one location to another. Rittal offers height-adjustable support arm systems from the CP series with a longer support profile for loads of up to 15 kg. With a system length of 1,100 mm, the system is 310 mm longer than the previous height-adjustable support profiles in the series. It also offers almost 400 mm more lifting height.
The support arm can be integrated into the support arm system without an adapter. On the wall or machine side, it is mounted on the 'CP 120' support arm system, while on the machine operator side, the support profile is attached to the 'CP 60' system. Pre-assembled cables with plugs can also be fed through without any problems. The cables are safely protected against environmental influences thanks to protection class IP54; the protection class is also maintained by the integration of the height-adjustable support arm.
Rittal
Change in the management
Markus Asch has been CEO of the Rittal International Foundation and Chairman of the Rittal Management Board since February 1, 2021. He was appointed by Prof. Friedhelm Loh, owner and CEO of the Friedhelm Loh Group.
Friedhelm Loh Group
Managing Board expanded
The Friedhelm Loh Group is aligning its group of companies for the future and is expanding its Executive Board to include Prof. Dr. Niko Mohr. He joins owner and CEO Prof. Dr. Friedhelm Loh and CFO Ralph Lindackers on the Executive Board.
