Optris at the SPS 2022Outdoor protective housing in IP66
In order to be able to use the infrared cameras of the PI and Xi series, for example, even under adverse conditions, Optris offers an outdoor housing that protects the sensitive devices.
The FT 25-RLHP time-of-flight sensor from Sensopart uses red light to detect objects up to 1.5 m away. The measuring process is housed in a compact miniature housing. This means that the sensor can be integrated into systems where space is limited. Its light spot is small and precise, while laser class 1 allows operation without protective measures. A window mode, which can be activated by pressing a button, also enables area monitoring: non-relevant distance areas can be masked out, for example the foreground and background of a conveyor belt. The switching frequency at which the sensor should work can be set. In addition to a digital switching output, the sensor has an IO-Link interface of specification 1.1.3. and the smart sensor profile. Typical applications include checking the presence of boxes and trays when they are removed from a high-bay warehouse, checking the position of components in assembly processes or for material flow control.
SPS 2022: Hall 4A, Stand 411
