Rafi
Digitize non-networked areas
Rafi launches the KIS.ME communication and process control system, which serves to digitalize non-networked work, logistics and production areas.
© Rafi
The plug & play solution enables the signaling of events and statuses at the touch of a button or transmitted sensor values and allows manual workstations, remote delivery zones, pick-up points or older machines to be connected to the control system. The solution is based on WLAN-capable push-button boxes and RGB signal lights, which are networked via Rafi 's 'KIS.Manager' web platform and configured for specific applications using logical rules.
For the automated recording of statuses or events, the 'KIS' hardware components each integrate four I/O connections via which sensors or control signals from machines or systems can be connected directly. The input signals processed according to individual rules can optionally control different color states of the signal lights, switch the digital outputs of the push-button boxes or trigger the sending of e-mail notifications.
Rafi
Signaling of three operating states
Rafi is expanding its 'Rafix 30 FS+' range of control and signaling devices to include an LED signaling light with a stainless steel front ring that is just 3.45 mm flat and is suitable for signaling three signaling states thanks to its integrated...
Rafi
Placed directly on the touchscreen surface
Rafi equips the 'Glasscape' touchscreens with haptic operating solutions: The Flexscape One and Flexscape Wheel control elements are placed directly on the touchscreen surface and enable safe function control without visual contact.
