Mallet
Designed in protection class IP65/IP67
Georg Schlegel expands the 'Shortron connect' series with two additional emergency stop devices.
© Mallet
The M12 connections of these emergency stop variants are 5-pin and A-coded, the connection pins are designed according to the AIDA principle.
As with all control devices in the Schlegel series, the degree of protection is IP65/IP67, both from the front and the rear. The FRVKOO_C111 has two NC contacts, the FRVKOOI_C112 has two NC contacts and one NO contact. The NC contacts are positive opening in accordance with EN 60947-5-1.
Georg Schlegel
Modular bus system expanded
The modular bus system MBS from Georg Schlegel is a proprietary bus system that can be integrated into fieldbus systems such as Profibus DP, AS-Interface or CANopen as well as industrial Ethernet networks such as Profinet, Ethernet/IP, Ethercat or...
Georg Schlegel
Suitable for rail transport
The Schlegel charging sockets are available in three versions, each with two USB ports from the combinations of USB-A and USB-C: A/A, A/C and C/C. The USB-A port delivers up to 2.4 A, the USB-C port up to 3 A charging current at 5 V output voltage.
