Servomotors
Quelle: Servotecnica | Inka Krischke,
Power up to 400 W
The brushless mini motors of the SVTN A series from Servotecnica with diameters from 12 to 40 mm achieve outputs of up to 400 W despite their small dimensions.
© Servotecnica
The lightweight and low-noise miniature drives are suitable for applications in medical technology, robots and active prostheses or exo-skeletons, for example. According to the manufacturer, the mini motor technology offers high torque and high speed or rotational speed with a particularly small size. The lack of cogging torque, low torque ripple, the linear correlation between speed and torque and the low mass inertia result in higher performance and dynamics. The dynamics are also improved by the smaller weights and dimensions. The mini motors can be equipped with Hall sensors and offer the option of mounting optical or magnetic encoders for high-precision speed control. They are also available with integrated electronics and fieldbus connection. If required, they can also be fitted with attachable high-precision gearboxes.
Oriental Motor
For predictive maintenance
According to the manufacturer, the new incremental encoder from Oriental Motor is particularly suitable for use in predictive maintenance thanks to its precision in measuring speed, position and direction of rotation.
