Take part and winProducts of the year 2023 - your vote counts!
96 products in 12 categories are up for election for the "Products of the Year 2023"! Take part and win Saturn vouchers worth €500, among other things!
8 of 9
Products of the Year 2023 - Nominated in the Measurement Technology category: Adamczewski Elektronische Messtechnik
© Adamczewski Elektronische Messtechnik
Adamczewski Elektronische Messtechnik - Centralized management of 32 measuring stations
Adamczewski Elektronische Messtechnik presents the AD-MM 500 FE monitor module. It is designed to help with data output and reading out individual measurement data. The device combines a display and control unit as well as a data logger in a compact housing for front panel installation. It acts as a Modbus master and processes the signals from up to 32 different measuring stations. The module can also be parameterized, whereby setups can be preconfigured and, if required, loaded using a PC. The recorded values can be shown graphically in different ways on the integrated display. At the same time, the data is logged according to selectable time or limit value specifications so that manual checking is no longer necessary. The monitor module for control cabinet mounting is suitable for a wide range of measuring devices and applications - this is made possible by the configuration options and the RS485 bus with Modbus RTU protocol as the communication standard.
>> Directly to the vote!
8 of 9
