Current productsNews from drive technology
Without drive technology - in the truest sense of the word - nothing would turn in most machines and systems. Computer&AUTOMATION presents the latest innovations in this automation discipline in a series of pictures.
11 of 15
Drive series 711C 2 B for winch systems from Bonfiglioli
© Bonfiglioli Deutschland
Bonfiglioli is expanding its product range with the 711C 2 B drive series for winch systems. Thanks to its compact dimensions, the coaxial planetary drive with a maximum output torque of 25,000 Nm can be easily accommodated in the winch drum. The oil seal, gear profiles and bearings of the drive are low-vibration. The design of the gearbox flange facilitates assembly, withstands harsh environmental conditions with ambient temperatures from -25 to +50 °C and simplifies maintenance thanks to lifetime lubrication that does not require oil changes. External oil cooling connections are available to operate in high ambient temperatures. In such cases, the gearbox can be equipped with a gearbox oil temperature sensor to monitor the gearbox oil temperature. The drive is also connected directly to the electric motors.
11 of 15
