Current productsNews from drive technology
Without drive technology - in the truest sense of the word - nothing would turn in most machines and systems. Computer&AUTOMATION presents the latest innovations in this automation discipline in a series of pictures.
KEB is expanding its range of servo inverters: The Combivert S6 single-axis servo inverters cover the lower power range up to 5.5 kW with a servo-type overload of 250 % in two sizes and are primarily aimed at applications with high dynamics. For the wide power range from 4 to 400 kW, the Combivert F6 is available in four initial sizes, serving powers up to 90 kW. The universal S6/F6 drive controllers are available in two technical versions with identical functions: "K-Control" has everything on board - from Ethercat, CAN, STO to the multi-encoder interface. "A-Control" offers flexibility with regard to various safety modules and real-time Ethernet connections. Open or closed-loop operation of all common motor technologies is always available. From 30 kW, the series offers air cooling as well as liquid cooling, both for control cabinet installation or as through-hole versions.
