SPS 2019New products in Nuremberg
What new products did the exhibitors present at SPS 2019? Computer&AUTOMATION provides an overview of what awaited visitors to the Nuremberg exhibition halls this year.
20 of 75
45_Compact Cat 6A control cabinet bushing from Friedrich Lütze
© Friedrich Lütze
Lütze is launching a Cat 6A control cabinet feed-through onto the market, with which control cabinet and machine builders can implement real-time-capable 10 Gbit/s service interfaces via Profinet, Industrial Ethernet or Sercos in the extended temperature range of -45 to +85 °C.The feed-through is also available with a straight 180° or angled 90° RJ45 outlet for the inside of the enclosure. The feed-through has an 8-pin and X-coded M12 socket with IP67 protection for connection on the outside of the enclosure. There is an 8-pin RJ45 socket on the inside of the enclosure for connecting standard patch cables. The lock nut for mounting in the enclosure is included in the scope of delivery. The feed-through has a robust housing and continuous 360° shielding. The mechanical service life of the control cabinet bushing is designed for more than 100 mating cycles. The installation depth is 47 mm. The cabinet feed-through can also be used for Power over Ethernet (PoE) applications, meaning that a separate power connection for selected devices can be omitted.
20 of 75
