Hanover Fair 2016New products in Hanover
"Integrated Industry - Discover Solutions!" was the motto of the world's most important industrial trade fair, Hannover Messe 2016. Computer&AUTOMATION shows an excerpt of the products that were on display in Hanover in a picture gallery.
9 of 46
LCOS PS switched-mode power supply from Lütze
© Lütze
The single-phase and primary switched-mode power supply LCOS PS from Lütze is adjustable on the output side in a voltage range of 23 to 27.5 V and has an AC wide-range input of 88 to 264 V. It has external dimensions of 35 mm × 100 mm × 110 mm. The efficiency is specified as greater than 94 %. The device features also include increased protection against overvoltage, PFC (Power Factor Correction) and a fault signal output. The switching power supply can be switched on the output side via the remote channel and offers a power boost of 150 %. The parallel operation of several switched-mode power supply units is easy to configure via a downslope characteristic curve. The 'LCOS PS' switched-mode power supply units from 30 to 120 W have a uniform housing structure and are designed for use in the modular 'LCOS' housing system or for top-hat rail mounting. The 120 W switched-mode power supply can optionally be operated on the internal data or power bus of the 'LCOS' enclosure system, and a sense connection for automatic voltage readjustment can be set up. The device can be used in a temperature range between -25 and +50 °C without derating and complies with protection class IP20.
9 of 46
