Product picture galleryInnovations in drive technology
Without drive technology - in the truest sense of the word - nothing would turn in most machines and systems. Computer&AUTOMATION presents the latest innovations in this automation discipline in a series of pictures.
13 of 19
Simotics S-1FG1 servo geared motor from Siemens
© Siemens
Siemens is expanding its drive portfolio for servo applications with the Simotics S-1FG1 servo geared motor, which is matched to the Sinamics S120 inverter system. The seamless integration of this drive system into Totally Integrated Automation (TIA) is designed to enable simple project planning and commissioning. According to the manufacturer, pre-assembled Motion Connect signal and power cables enable the components to be connected easily and without errors. The electronic type plates on the components and the connection of the motors via the Drive-Cliq system interface should help with commissioning. The servo drive system is suitable for use in printing and packaging machines, storage and retrieval machines, conveyor systems and dosing pumps, for example. The Simotics S-1FG1 motor is available in helical, parallel shaft, bevel gear and helical worm gear versions - in up to 25 ratios depending on the gearbox type and size. The Sinamics S120 inverter system is available in four different designs: blocksize, booksize, chassis and cabinet unit.
13 of 19
