ABM Greiffenberger at the SPS 2022Frequency inverters up to 2.2 kW for intralogistics
ABM Greiffenberger completes the inverter series for container and pallet conveyor technology with two sizes specially developed for intralogistics. With the power range up to 2.2 kW, even higher loads can be moved.
6 of 11
© ABM Greiffenberger
ABM Greiffenberger has extended its existing flat gearbox series (FG) with the types FG182 and 282 especially for container and pallet conveyor technology in intralogistics. The compact two-stage solutions offer nominal torques of 180 and 280 Nm and can also be used as crane travel drives due to their transmission ratio and compactness. Users also benefit from high permissible radial loads as well as universal mounting options such as hollow and solid shafts, shrink disk, versions with and without flange. In addition, their low weight and compact dimensions make them easy to handle during installation.
SPS 2022: Hall 3A, Stand 400
6 of 11
