Sieve & MeyerFrequency inverter series expanded
Sieb & Meyer presents the SD4S, SD4M and SD4B, the latest models in the SD4x series of frequency inverters for high-speed applications.
6 of 11
© Redur
The cable conversion transformers from Redur have a robust multifunctional housing made of flame-retardant polyamide (V2 according to UL 94, optionally also V0) with variable mounting options. The patented click-off hinge can be removed, making the upper part of the cable conversion transformer, the hinged transformer, completely removable, according to the manufacturer. This should make installation easier, even in difficult and tight installation conditions. The spring system also ensures a constant contact pressure of the core halves.
This ensures consistent measured values for years to come. The cable conversion transformers comply with insulation class H and are designed for a maximum operating voltage of 0.72 kV. Optional plug-in feet for mounting on mounting plates or snap-on fastenings for installation on top-hat rails are available for the hinged transformers. The cable conversion transformers are also suitable for retrofitting, as they can be integrated into the application without dismantling system components.
SPS 2022: Hall 4, Stand 300
6 of 11
