RotekEasier drive selection with configurator
The Rotek website has been redesigned and now features a configurator.
10 of 10
Lapp at the SPS
© Lapp
Lapp is launching two switches for use outside the control cabinet: thanks to IP67 classification, the Etherline Access PN IP67 Profinet switch and the Etherline Access U IP67 unmanaged industrial Ethernet switch are suitable for use directly in the field. Etherline Access PN IP67 with eight ports (10/100Base-T(X)) for D-coded M12 connectors is particularly suitable for Profinet networks in automation technology (Conformance Class B). It can be used in the extended temperature range from -40 to +75 °C. The managed switch prioritizes Profinet telegrams with real-time data and enables configuration and diagnostics via Profinet or web interface. MRP (client), LLDP, DCP and SNMP are supported. The unmanaged industrial Ethernet switch with eight ports (10/100Base-T(X)) for D-coded M12 connectors has a 16 K MAC address table and 256 Kbyte packet buffer. It is suitable for use in Profinet networks (Conformance Class A) and can be used in the extended temperature range from -40 to +75 °C.
SPS 2022: Hall 2, Stand 310
10 of 10
