Nabtesco at the SPS 2022Cycloidal gears for heavy-duty robots
For use in heavy-duty robots, Nabtesco offers a graduated product portfolio of gearbox systems with nominal torques of up to 28,000 Nm.
9 of 11
© ABM Greiffenberger
ABM Greiffenberger completes the inverter series for container and pallet conveyor technology with two sizes specially developed for intralogistics. With the power range up to 2.2 kW, higher loads can also be moved. According to the manufacturer, the frequency inverters offer optimum control characteristics for both asynchronous and synchronous 'Sinochron' motors. They can operate the permanently excited synchronous motor without sensors, which reduces costs and increases availability. The devices are designed for a service life of 30,000 hours under full load and continuous operation. Plug-in connections enable quick and easy installation. The inverters communicate with higher-level control systems via Ethernet-capable bus systems. Users receive the frequency inverters with a protection rating of up to IP54 and an overload capacity of 250 %. The devices are suitable for temperatures from -30 to +40 °C.
SPS 2022: Hall 3A, Stand 400
9 of 11
