Crane motors
Quelle: Siemens | Inka Krischke,
Fulfill efficiency class IES1/IES2
According to the manufacturer Siemens, the Simotics DP crane motors are now more energy-efficient and compact and are based on the "1LE1" platform. The gray cast iron motors were specially developed for humid, salty air in container ports around the world.
© Siemens
They comply with efficiency class IES1/IES2 on the inverter and work in hoist, trolley, slewing, luffing and travel units. The product range starts with axle height AH132 and extends up to axle height AH315L. Both non-ventilated and ventilated designs are available for crane-typical intermittent operation. The outputs range from 1.1 kW to 481 kW with all common voltages and torques from 10 to 4600 Nm. According to the supplier, the motors have a high overload capacity and a speed setting range of 730 to 1730 rpm. The overload capacity of up to 450 % in some cases ensures large torque reserves for high impact loads. Various crane-specific attachments such as special brakes for safe stopping or pulse generators for speed detection for inverter control are optionally available. The motors are protected against ambient temperatures up to +40 °C - optionally even higher -, against humidity up to 100 % and against salty atmospheres.
Logistics systems
New products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of...
Box PCs
IoT device for logistics
The new 'Vehicle Computer Compact M8' embedded box PCs from Syslogic have no moving parts, are shock and vibration resistant and are designed for an operating temperature range of -40 to +85 °C.
Embedded PCs
Suitable for vehicle installation
With the Nuvo-5100VTC, Industrial Computer Source presents an embedded PC that is E-Mark and EN-50155-certified and is therefore suitable for installation in vehicles. The devices are equipped with sixth-generation Intel Core i7, i5 and i3 CPUs.
Tablet PCs
Optional UPS module available
The outdoor tablet PC model 'UPC-F12C-ULT3' from Comp-Mall in an aluminum housing can be used as a mobile or stationary device and is protected against dust and splash water thanks to its all-round IP65/IP66 protection class.
