Oriental Motor
Brushless DC motors with driver
The motors in the BLH series from Oriental Motor are available with spur gears, flat gears or without gears with a round shaft and with rated outputs of 15, 30, 50 and 100 W.
© Oriental Motor
Depending on the power, the flange dimension of Oriental Motor 's motors is between 42 and 90 mm. Thanks to their optional electromagnetic brake (except 15 W version), they act as a drive solution for vertical or other applications where the load must be held by the brake in the event of a power failure. According to the manufacturer, the motors exhibit only minor speed deviations (±0.2 % or ±0.5 % depending on the driver) even with load changes or synchronous operation. Thanks to these properties, they help the respective application to achieve higher cycle rates, for example when used for belt drives or as a drive in automated guided vehicles. Users can choose between three different drivers: In addition to an analog and a digital setting, a driver with an RS485 interface is also available.
