AI-Supported Automation
Andrea Gillhuber,
Siemens and ServiceNow Announce Cooperation
Siemens and ServiceNow have partnered to enhance industrial cybersecurity and drive the integration of generative AI into production environments.
© Siemens
The companies are focusing on combining Siemens' "Sinec Security Guard," designed to enhance cybersecurity in production, and the "Siemens Industrial Copilot" for generative AI-driven automation, with ServiceNow's workflow automation. This integration allows results generated by AI from the Siemens Industrial Copilot to be directly embedded into ServiceNow workflows.
A key component of this partnership is ServiceNow's "Operational Technology Service Management Suite" (OTSM). This suite helps companies manage and secure their operational technology environments by integrating IT and OT workflows, providing real-time visibility, and automating processes across the shop floor. By integrating Sinec Security Guard, ServiceNow's OT Vulnerability Response (OT VR) capabilities are further enhanced, enabling deeper insights into OT device vulnerabilities and allowing for faster identification and remediation of security threats.
ServiceNow’s Now Platform coordinates and manages complex automation workflows and integrates AI into operational processes, while Siemens contributes extensive industry expertise in the automation sector. The Siemens Industrial Copilot, built on generative AI, fosters better long-term collaboration between humans and machines in production environments. Companies using the Now Platform to structure their workflows can achieve even greater transparency with the Operations Copilot, as static and dynamic machine data provide visibility and control. The Operations Copilot supports production workers with detailed instructions and recommendations in natural language.
ServiceNow automates workflows—from maintenance planning to real-time problem-solving. This helps turn AI-generated insights into tangible, efficient actions, ultimately enhancing productivity and minimizing downtime.
TrendAI
Deutschland bei Ransomware unter Top drei
Der Cyber Risk Report 2026 von TrendAI zeigt: Deutschland gehört bei Ransomware-Angriffen weltweit zu den drei am stärksten betroffenen Ländern. Gleichzeitig sinkt das durchschnittliche Cyberrisiko von Unternehmen leicht.
Adlon
OT ist nicht länger offline
Die Produktion ist heute so vernetzt wie nie und dadurch attraktiv für Angreifer. Die Angriffe verlaufen hybrid, beginnen in der IT und wirken in der Produktion. Ein Security Operations Center (SOC) bleibt in diesem Umfeld nur dann wirksam, wenn es...
Moxa
Risiken in der Feldebene absichern
Maschinenbauer müssen im Rahmen des Cyber Resilience Act Sicherheitsrisiken systematisch bewerten und minimieren. Beispiele aus der OT-Praxis zeigen typische Schwachstellen und mögliche Gegenmaßnahmen auf der Feldebene.
Bihl+Wiedemann
Zukunftssicher automatisieren
Illumio
Warum IT/OT-Grenzen neu gedacht werden müssen
Smart Factories verbinden Produktionsanlagen, Steuerungen und IT-Systeme über gemeinsame Netzwerke – eine Entwicklung, die die Effizienz zwar steigert, aber auch zusätzliche Angriffsflächen schafft. Um diese Risiken zu beherrschen, müssen...
