Baumer
Optimal use of IO-Link
The Baumer Sensor Suite is a PC software for the development and use of smart sensor solutions. Its intuitive operation and graphical representation of sensor functions make it easier to evaluate, select and parameterize IO-Link devices.
The Baumer Sensor Suite (BSS)
© Baumer
The Baumer Sensor Suite 'BSS' is manufacturer-independent, which means that all IO-Link devices available on the market can be parameterized. This also applies to several third-party IO-Link masters. The USB-C IO-Link master from Baumer is tailored to this. It enables the simple connection of IO-Link devices to the 'BSS' in less than a minute. With the USB-C interface, data exchange and power supply are realized via a connection cable.
Baumer
Temperature-resistant up to +140 °C
The PAC50 process sensor from Baumer measures conductivity in the smallest of spaces and is therefore particularly suitable for small production systems, for example in the food and pharmaceutical industries as well as in industrial applications.
Baumer
Process transparency through color display
When measuring the limit level with the 'CleverLevel PL20' limit level switch from Baumer, five defined colors of the KingCrown process visualization provide an insight into whether the limit level has been reached, which medium is in the tank or...
Baumer
The all-round view
Rotationally symmetrical objects in the pharmaceutical, food and beverage industries are often rotated once around their own axis during inspection and the images captured in the process are compiled afterwards. An alternative is a system with four...
