What would the smart factory of today and tomorrow be without sensors? Sensors are indispensable as the basis of every industrial production system. Computer&AUTOMATION summarizes current trends from spring 2016 in a series of images.
© Jumo
Jumo, supplier of temperature and pressure measurement technology as well as liquid analysis, is expanding its portfolio with the Flowtrans MAG S01 and Flowtrans MAG H01 electromagnetic flow meters. The 'Flowtrans MAG S01' is the standard version of the series. It is available for nominal diameters from DN 10 to DN 300. The Flowtrans MAG H01 with nominal diameters from DN 3 to DN 100 has been specially developed for hygienic applications. The minimum conductivity of the measured medium must be greater than 5 µS/cm for both devices, and the maximum temperature is +130 °C, depending on the version. Both flow meters are available either as a compact device or with a separate transmitter. Configuration is carried out either directly on the device or using PC software. The transmitter automatically recognizes the sensor, after switching on the power supply the data is automatically loaded from the 'SensorMemory'. The device is operated via a freely configurable display with backlighting. The integrated diagnostic functions can be used to monitor the functionality of the transmitter electronics and the sensors as well as the operating conditions.
