Jumo
Can be used in fresh and salt water
Thanks to the latest optical technology of fluorescence quenching and digital signal processing, the 'Digiline O-DO S10' from Jumo enables long-term stable measurements of oxygen and temperature.
© Jumo
The sensor housing is made of resistant PVC so that the sensor can be used in both fresh and salt water. Based on the connection concept of the 'Jumo Digiline' bus system, it can be quickly connected to the 'Digiline' master via Plug&Play. The system also enables more efficient cabling of systems in which several parameters need to be measured simultaneously at different points. The sensor management integrated in the sensor records and logs relevant operating data over the entire sensor life cycle in order to optimize processes and procedures. This includes the recording of operating hours and functions that enable predictive maintenance, such as the timely signaling of a required calibration or a necessary sensor cap change. An RS485 Modbus RTU interface and an analog output (4 to 20 mA) allow system integration with field devices and process control systems. The measuring range of the sensor is 0 to 20 mg/l, the temperature range in which it can be used is between -5 and +50 °C.
Jumo
Continuously measured
Safety PLCs are not always necessary to implement safety requirements in tank systems. In some cases, the use of safety monitors or limiters is also sufficient.
Jumo
Supplemented by three modules
The Varitron automation system from Jumo is being extended by three modules: The 32-channel digital I/O module offers 32 channels, 17 of which are configured as digital outputs as standard.
Kistler
IO-Link technology included
With the 5028A charge amplifier, Kistler is launching a charge amplifier that can output analog signals from piezoelectric sensors as digital measurement data using IO-Link technology.
Jumo
Use in hazardous areas
Especially in chemical or process engineering processes, additional heating is required to maintain or increase the temperature in order to optimize the complex processes of modern industrial plants. But what needs to be considered here?
SMSI 2021
New submission deadline for presentations
The AMA Association for Sensors and Measurement has opened the new Call for Papers for the international conference 'Sensor and Measurement Science International (SMSI) 2021'. The conference will take place parallel to Sensor+Test from May 3 to 6,...
Corona
No access! Please wait!
How can it be ensured that the number of people permitted in premises is not exceeded in light of the coronavirus pandemic? Two automation companies - Pepperl+Fuchs and Schmersal - present their technical solutions.
TWK
Detect alignment and speed simultaneously
TWK has expanded its family of inclination sensors with a special device that makes it possible to precisely measure the current orientation - i.e. the inclination or position (360°) - and the speed at the same time in a rotating application.
