Georg Schlegel
Operating temperature from -25 to +70 °C
Schlegel has added an emergency stop for the 22.3 mm installation opening to the 'Shortron M12' series. The small and compact FRVKOO_M001 with rotary release has protection class IP65/IP67 from the front and IP65 from the rear and is therefore also suitable for environments with splash water.
© Georg Schlegel
The two contacts (AgNi) of the emergency stop are designed as normally closed contacts (NC) and are positive opening in accordance with EN60947-5-1. The emergency stop has a service life of up to 50,000 switching cycles and is designed for operating temperatures from -25 to +70 °C.
The 4-pin M12 connection is A-coded and connected to the emergency stop via a 25 cm long PUR cable. According to the supplier, the electrical characteristics are within a range of maximum Ue 35 V operating voltage and operating currents of Ie 4A (AC15) or Ie 2A (DC13). The emergency stop complies with the EN ISO 13850 and EN 60947-5-5 standards.
Mallet
Emergency stop with pull release
Georg Schlegel has come up with a special design for the new emergency stop variants with pull release in the 'Shortron' series: In addition to the mushroom-shaped push-buttons, there is also an emergency stop with a ball head or in cylinder form.
ISH
FuSi from the modular system
The development effort for functional safety is hardly affordable, especially for small and medium-sized companies - particularly from an economic point of view. A certified safety construction kit can provide a remedy here.
