SchunkElectric, configurable large lifting gripper
Schunk presents the electric universal gripper EGU.
SEW-Eurodrive is expanding its portfolio to include motors for pure inverter operation: The DR2C.. series synchronous motors meet the highest standardized efficiency class IE5 for variable-speed electric motors. Thanks to the design as a synchronous motor, the speeds of the IE5 motors are not load-dependent. Interlinked system components can therefore be designed without power in the transition. Another advantage of synchronous motor technology is the virtually lossless rotor and thus the low thermal load, as a colder motor has a longer service life. The motors will be available in spring 2023 with outputs of up to 3 kW. They achieve efficiencies of up to 91 %; higher outputs of up to 11 kW in IE5 will follow in late 2023 with efficiencies of up to 94.5 %. Energy-optimized drive solutions are created in combination with all the possibilities of the frequency inverters from the 'MOVI-C' modular automation system.
SPS 2022: Hall 3A, Stand 411, 711
