Track systems
Quelle. B&R Industrial Automation,
Withstand high pressure and dust
B&R now also offers the 'Acopostrak' track system in protection class IP69K. In this version, the track can be cleaned with high pressure and temperatures of up to 80 °C and is also fully protected against dust.
© B&R Industrial Automation
The track system can therefore be used in industries with the highest cleaning requirements, for example in the pharmaceutical or food industry. The shuttles and segments of the new version are made of stainless steel, are welded and resistant to corrosion. This makes it possible to transport corrosive products and operate the Acopostrak in corrosive atmospheres such as salt spray. All surfaces of the track are chemically resistant. This means that no particles or fluids from the environment can penetrate the interior of a shuttle or segment. Acopostrak can be modularly expanded with individual track elements and processing stations. This makes machines scalable and allows them to be adapted to production requirements at any time.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
