Beckhoff Automation
Thomas Kosthorst | Andrea Gillhuber,
PC-based control reduces cycle times
Producing a wide variety of packaging designs with high flexibility and minimum cycle times - at the Swiss company Beck Automation, PC or servo-based control plays a key role in meeting this requirement.
© Beckhoff Automation
Beck Automation in Oberengstringen was founded in 1934 and, with over 30 years of experience, is a pioneer in the field of in-mold labeling systems. The spectrum of machines ranges from cost-effective basic systems to customer-specific special machines. A current example of the innovative solutions from the family-run company from Switzerland is a 6-cavity IML system for decorating plastic lids, the use of which is explained by Nino Zehnder, Sales Manager and Member of the Management Board at Beck Automation: "This system is used for plastic packaging in the food sector. The most common product manufactured with it are lids for 1-liter cans for yoghurt, for example. However, the same machine can also decorate the can itself."
In each process step, the IML system removes six labels from a magazine and inserts them into the open mold of the injection moulding machine.
With in-mold labeling, an already printed label is placed in an injection mold that has the shape of the desired end product - for example, the lid of a yogurt can. Plastic is then pressed into the mold. The plastic cools down in the mold, hardens, bonds with the label and ultimately forms the finished end product. According to Nino Zehnder, this process is characterized by its very high flexibility compared to film printing: "From the perspective of batch size 1 production and Industry 4.0, IML is particularly suitable for packaging design. This is because no expensive and time-consuming printing machine process has to be converted in the event of changes. This means that up to 5,000 plastic lids can be produced per hour and, in extreme cases, each of them can be produced with a new design or an individual QR code."
For precision and a long service life, the IML system is based on a solid steel frame. It is positioned at the side of an injection molding machine. The actual core of the system is its servo-controlled main arm. This arm moves into the open injection mold, removes six finished lids on one side and simultaneously inserts six new labels for the next injection molding process on the other side of the mold. During this process, the IML system processes the removed lids, i.e. they are checked for quality using a vision system and then stacked. At the same time, the next six labels are separated in order to load the main arm for the subsequent insertion into the open injection mold.
"The entire cycle with six plastic lids at a time only takes around four seconds," says Nino Zehnder, illustrating the efficiency of the IML system, adding: "It can also be quickly and easily changed to a different size, shape or number of lids. Another advantage is the automatic magazine change, which allows the labels to be refilled without interrupting the process."
The advantages of PC-based control technology
Beck Automation decided to use PC-based control back in 2011, as Christoph Jenni, head of the software department, explains: "PC-based control technology already had a number of fundamental advantages back then - for example, easy remote access for supporting our systems directly at the customer's premises. With the Beckhoff solution, the online change option was another useful feature. Compared to the previous PLC-based solution, we benefited not least from the powerful axis control with comprehensive diagnostic options and the use of the fast Ethercat communication standard as a replacement for the previous individual wiring." Nino Zehnder adds the specific advantages of a Windows-based system: "The corresponding openness ensures maximum flexibility. For example, data evaluations can be saved directly as an Excel spreadsheet without much effort or a wide range of options for a user-friendly HMI can be used."
The focus remains on the modularity and good scalability of PC-based control, as Christoph Jenni confirms: "Depending on the machine size and equipment, the control technology can be optimally adapted without requiring a great deal of engineering effort. For example, the number of servo axes can be easily adapted to the respective requirements. In addition, PC-based control does not limit the number of I/O channels, leaving all options open."
The AX5000 servo drives together with the AM8000 OCT servomotors provide an efficient and dynamic motion solution.
Beck Automation has consistently used servo drive technology for the new 6-fold IML system. This offers great advantages due to the simplified adjustment of the system, especially during changeovers. The system has a total of four servomotors from the AM8000 series. These are controlled via two single-channel servo drives (AX5103/AX5118) or a dual-channel version (AX5203) and with the Twincat 3 NC PTP software. One of the four servomotors with a standstill torque of 29 Nm (AM8063) ensures an extremely dynamic movement of the main axis. In addition, there are two servomotors with 2.37 Nm (AM8032) and another with 3.22 Nm (AM8033), some of which are equipped with a holding brake. Among other things, this realizes the shuttle movement in order to be able to guide the plastic lids past the vision inspection system with a sufficiently short cycle time. In addition, the low-jerk servo drive technology, in contrast to pneumatics, has a positive effect on the service life of the system, as the inertia forces are reduced.
Two of the four servomotors used perform the main arm movement (motor top right) and the shuttle function (motor top left).
The other servo axes are used to remove the labels from the magazine and to stack the finished plastic lids. From Christoph Jenni's perspective, One Cable Technology (OCT) has also had a positive effect: "OCT significantly reduces the amount of cable and assembly work required. In addition, the electronic type plate simplifies commissioning, troubleshooting and any device replacement."
The embedded PC and the I/O level consisting of Ethercat and Twinsafe terminals are extremely compact.
An Embedded PC with an Intel Atom processor (1.75 GHz clock frequency) provides sufficient computing power for the entire control and Motion Control processes. Christoph Jenni sees a decisive advantage in the wide range of Industrial PCs from Beckhoff: "Depending on the requirements or system size, more powerful IPCs or multicore technology can also be used without great effort. The existing control software can be used in the same way. In this way, we are very flexible in terms of system design."
The same applies to the use of Twincat: "With the existing motion control library, we have been able to meet all our requirements so far. Special features such as data exchange via OPC UA were also easy to implement with the corresponding software function." The system-integrated safety solution has also resulted in further efficiency benefits. This is because the safety functions implemented via Twinsafe Logic and the Twinsafe option cards for the drives - safety gates and emergency stop - have significantly reduced the amount of wiring and space required.
Author
Thomas Kosthorst works in industry management for plastics machines/hydraulic applications at Beckhoff Automation.
New products
Beckhoff simplifies AI training
An evolutionary development every year, a revolutionary leap every five to seven years - this is how Beckhoff aims to secure its technological leadership. At the press conference, the company from Verl also presented some technological highlights.
Beckhoff
AI training made easier
An evolutionary development every year, a revolutionary leap every five to seven years - this is how Beckhoff aims to secure its technological leadership. At Hannover Messe, the company from Verl also presented some technological highlights.
Hanover Fair
HANNOVER MESSE DAILY Day 4
The top news from the fourth issue: Robert Habeck at the trade fair tour +++ Technological AI highlights from Beckhoff +++ Radar sensor technology in focus at Pepperl+Fuchs +++ ASi-5 counter module as an active distributor from Bihl+Wiedemann +++...
