Weidmüller
Fast PLC/PLS migration
Weidmüller's 'MiBridge' can be used to replace a PLC/PLS without the need for time-consuming rewiring.
© Weidmüller
This migration solution from Weidmüller makes it possible to easily connect I/O cards to the existing field wiring via an adapter card, so that the existing field wiring can continue to be used without restriction. The connection is made directly via the existing field wiring connector. Depending on the existing installation, MiBridge offers three different solutions for quickly replacing the PLC/PLS: bridge solution, card solution and system cabling with PLC/PLS transfer elements. With all solutions, the existing cabling is completely retained. With Card Solution, the mounting rack of the new system is added to the existing installation, allowing the new card adapters to be inserted into the existing adapters. In the case of system cabling with PLC/PLS transfer elements, only the DC cable and the PLC/PLS itself need to be replaced. MiBridge is compatible with PLC/PLS systems from different manufacturers.
Weidmüller
Everything from a single source
There will no longer be a separation between Industrial IoT and automation in the future. Weidmüller has therefore already laid the foundation for an open and holistic industrial IoT and automation portfolio with the Linux-based u-OS operating...
Delta Logic
Update brings support for TIA V19
Delta Logic has updated the 'Accon OPC UA Server' software to version 1.4.0.0. The new features include support for TIA Portal projects of version V19 and for the latest firmware for CPUs of the Siemens S7-1200 and S7-1500 controllers.
SPS 2024
Automation meets innovation
SPS - Smart Production Solutions will take place in Nuremberg from November 12 to 14. Once again this year, organizers and exhibitors will pick up on the trends in the automation industry and present suitable solutions. The introduction of IT into...
