E.E.P.D.
Industrial NUC box
The 'New Unit of Computing' (NUC) is an invention by Intel. E.E.P.D has made the form factor suitable for industrial use and installs processors from the 'AMD Ryzen Embedded V1000' platform.
The good performance per watt makes the system suitable as a high-performance IoT edge node that can take on intelligent tasks. Two displays with 4 K resolution and 60 Hz can be controlled via two Mini-DisplayPort connections.
Thanks to an automotive-grade power supply and extended temperature range, the system is also suitable for mobile applications, according to E.E.P.D.
