Spectra
Embedded system with Tiger Lake processor
Spectra launches the LP-1797 industrial Pico-ITX board with compact dimensions of 100 mm x 72 mm
© Spectra
It is based on the Intel Core i7-1185G7E processor with four cores and a clock frequency of 1.8 to 4.4 GHz at a TDP of 15 W. The RAM can be expanded up to 32 GB via a DDR4-3200 SO-DIMM slot. The CPU was installed on the back of the board, from where it can be cooled directly via a heat sink or via the housing. Image output in 4K quality is ensured by an Intel Xe GPU equipped with a total of 96 processing units.
Spectra has integrated an HDMI and DisplayPort for connecting displays. A VGA port is implemented via an internal pin header. Network connectivity is provided by an Intel I219-LM with 1 Gbit/s and an Intel I225-LM with 2.5 Gbit/s. Extensions are implemented with the help of an M.2 2280 slot for NVMe SSDs with PCIe 4.0 and an M.2 2230 slot for Wi-Fi or Bluetooth modules. Two USB 3.2, two USB 2.0 and one SATA3 as well as two RS-232 interfaces are also available.
Spectra
Scalable for BV applications
Industrial image processing ranges from simple applications in environmental perception such as positioning, measuring, identifying and sorting objects to more complex image processing-controlled automation functions.
Spectra
15 years available
For particularly compact embedded solutions, Spectra offers the 3.5-inch IB919 board series, which is available for a period of 15 years. There is a choice of four processor variants (Core i7/i5/i3/Celeron) of the Whiskey Lake generation.
Spectra
Powerful edge AI server
With the edge AI server from the PowerBox 500 series, Spectra offers system integrators a configurable, fanless embedded system for industrial image processing applications, among others.
