Softing Industrial
Günter Herkommer,
Securely into the cloud via MQTT
Softing has introduced a new version of the 'dataFEED OPC Suite'. This now includes an 'MQTT Connector', which is designed to make the transfer of data to IoT clouds simple and secure.
Andreas Röck, Softing: "Regardless of the current success of MQTT, OPC UA will become the leading protocol for communication between production and IT in the medium term with the help of the new publish-subscribe support."
© Softing
"A key challenge for the successful implementation of Industry 4.0 is the provision and analysis of production data. For plant manufacturers, operators and IT administrators, the key question is how and where they can store and analyze large volumes of data securely and cost-effectively. This is where we come in with our solution," says Andreas Röck, Product Manager Data Integration at Softing Industrial.
With the 'dataFEED OPC Suite', Softing combines OPC server and middleware in a compact software solution. The new 'MQTT Connector' is now intended to enable the integration of automation devices via publisher functionality in IoT cloud applications such as 'IBM Bluemix Cloud'. Maximum security during data transmission is guaranteed by encryption using SSL/TSL. According to Röck, the MQTT gateway enables both existing and new controllers to be easily integrated into IoT environments - including components without MQTT support, such as Siemens, B&R and Rockwell controllers.
When asked why Softing has chosen MQTT in particular in view of the variety of IoT protocols, Röck replies: "Of all IoT protocols, MQTT has the highest growth rates and is now supported by all major cloud providers such as Microsoft, Amazon, IBM and General Electric. At the same time, the number of applications available for connecting automation devices has risen sharply; Beckhoff, for example, has integrated the protocol into its control system." Last but not least, MQTT has the advantage over the other protocols that it is very lean, simple and extremely high-performance. Nevertheless, Softing is already working on integrating other IoT protocols such as HTTP REST into its 'dataFEED OPC Suite' in addition to MQTT over the course of the next year.
Start-ups
The 'Automation Hackathon'
At the 'Automation Hackathon' at SPS IPC Drives 2018, seven start-ups had the chance to develop new business models for selected companies in the automation industry in 48 hours. Winner: the start-up Othermo in collaboration with Wago.
Synapticon
Entering the Machine Building Business
Known as a technology supplier to robot manufacturers, Synapticon now plans to offer targeted solutions for machine builders. The kick-off was given at the SPS IPC Drives with the ‚Actilink‘ drive systems and a quick-start package for the production...
