HMS Networks
Range of embedded communication interfaces expanded
© HMS Networks
HMS Networks is launching another version of the embedded communication interfaces 'Anybus CompactCom'. 'Anybus CompactCom B40 Mini' complements the 40 series with a communication interface that is optimized for automated production.
Anybus CompactCom is a product family of ready-to-install embedded communication interfaces for connecting automation devices to all major industrial networks. The 'B40 Mini' complements the existing range of slide-in modules and plug-in brick solutions with a solder-on brick solution. It is soldered directly onto the carrier board of the automation device and, according to HMS Networks, is 30% smaller than the plug-in brick solution. This makes it particularly suitable for small automation devices. The communication interface is supplied on tape and reel, is optimized for automated production with pick & place and SMD soldering processes and is designed for high quantities. The B40 Mini has the industrial Ethernet networks Profinet, Ethernet/IP, Powerlink, Ethercat, Modbus-TCP and BACnet/IP pre-installed and can also be supplied preset for a specific network.
Cybersecurity
Profinet enables CRA conformity
The EU Cyber Resilience Act (CRA) will require all manufacturers of products with digital elements to implement comprehensive security measures from December 2027. After a thorough review of its technologies, Profibus & Profinet International...
