Balluff
Connect drive technology directly
Balluff offers special Ethernet/IP network modules for assembly and conveyor technology. The IO-Link masters BNI00EF and BNI00EH enable the fast integration of different IO-Link devices into existing networks.
© Balluff
They have several ports with 4 A output current for connecting drive technology such as 24 V (DC) motors or electric stoppers. With their robust zinc die-cast housing with IP67 protection, they are designed for a decentralized system architecture outside the control cabinet. There they act as data compressors and help to reduce the number of network nodes to a minimum.
Balluff is exhibitor at SPS Connect
© WEKA Trade Media
If these I/O modules are used in combination with IO-Link hubs, the signals of several binary and/or analog field devices can also be collected from the area and condensed to one port. According to Balluff, digital data transmission via IO-Link ensures high signal quality. Parameterization and error analysis of the IO devices are carried out in the controller as is typical for IO-Link.
The active distributors are available as versions with eight IO-Link ports (16x I/O) or four IO-Link ports (8x I/O). The dimensions are 68 mm x 37.9 mm x 220 mm or 37 mm x 32.6 mm x 224 mm.
Balluff
Condition monitoring 'to go
With the Portable Monitoring System, Balluff offers a cloud-based complete package for condition monitoring of systems and machines - consisting of a condition monitoring sensor, mobile gateway and intuitive visualization software.
Balluff
Read out data via IO-Link
Reliable and wear-free monitoring of the clamping process plays a central role in tool spindles and tool changers of a machining center. Balluff offers the BIP01 inductive position measuring system for this task.
Balluff for SPS Connect
Simply retrofitted
Last year, Balluff introduced the 'BCM' condition monitoring sensor, which records four measured variables with just one device. Stefan Hornung, Portfolio Manager for Condition Monitoring Solutions at Balluff, explains what has happened since then...
Balluff
Smart sensor technology for the IIoT
In addition to status information, intelligent sensors provide a wealth of secondary data - on service life, load level and damage detection as well as ambient temperature or contamination. Optical sensors in particular are undergoing a lot of...
