Cognex
Smart cameras based on deep learning
With the In-Sight D900 vision system from Cognex, the 'In-Sight ViDi' deep learning software is embedded in a smart camera. The camera is installed in the line without a PC.
© Cognex
The modular IP67-certified image processing system includes field-replaceable lighting, lenses and filters as well as covers that can be customized according to individual application requirements. High Dynamic Range (HDR+) imaging produces evenly exposed images. The LED display enables remote pass/fail evaluation and the test results can be saved locally on an SD card.
According to Cognex, an inference engine has been integrated specifically for the execution of deep learning applications. 'In-Sight D900' works with the easy-to-use spreadsheet user interface, which simplifies application development and factory integration. Application engineers have access to the full suite of traditional vision tools such as PatMax, edge finders and measurement tools.
With In-Sight ViDi, the D900 also has three deep learning tools:
ViDi Read, ViDi Check and ViDi Detect. 'ViDi Read' is ideal for OCR tasks, as the module deciphers deformed, distorted and poorly lasered codes using optical character recognition. 'ViDi Check' is used to check assemblies and component positions, while 'ViDi Detect' helps to detect defects and other undesirable deviations.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our weekly newsletter and keep your finger on the pulse of automation time. Once a week, on Tuesdays, we provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products. Stay up to date with us.
Our newsletters are of course free of charge and can be canceled at any time!
Click here to register.
Cognex
Automated inspection
Until now, optical inspection in 3D was associated with high programming effort and costs, meaning that users had to resort to 2D solutions. A new type of laser-based 3D vision system is now set to put an end to this.
Cognex
Integrated OLED display
The DataMan 8700 series portable barcode readers are based on a completely redesigned platform, according to Cognex. The devices can read demanding DPM (Direct Part Mark) and label-based codes immediately, even if important elements of the code are...
