Wenglor
Precise illumination
The new spotlights from Wenglor with lockable zoom lens for a variable beam angle in the range from 4 to 26 ° with constant homogeneity enable a pinpoint lighting situation.
© Wenglor
Thanks to flash mode overdrive with an illuminance of up to 360,000 lux, a robust housing and flexible mounting options, the spot lighting from Wenglor is suitable as application lighting in industrial image processing. It is available in the light types white light, red light and infrared light. The aluminum housing with IP67 protection protects against environmental influences and enables quick and easy installation thanks to the M30 thread. Camera brackets provide flexible mounting options to keep the design effort to a minimum. The M30 proximity sensor mounts enable space-saving integration, which can also be used with swivel mounts. Magnetic polarization filters, which can be positioned using locking screws, reduce reflections from shiny surfaces.
Wenglor
Sales milestone reached
Wenglor, manufacturer of industrial sensor, image processing and safety technologies, has achieved an annual turnover of over EUR 100 million in 2021 - a first in the company's history.
Basler
Modular board level camera
With the 'dart M', Basler is launching a customizable board-level camera with GigE interface that adapts to the installation situation and existing electronics of the customer application thanks to its modularity and design.
