Vision Components
Embedded vision combined with Raspberry Pi
With the VC MIPI Embedded Vision Kit from Vision Components and a Raspberry Pi Compute Module 3 or 3+, a fully-fledged and industrial-grade embedded vision system can be set up quickly.
© Vision Components
The core component is the 'VC Compute Module Interface (CMI) Board', onto which the RASP CM is simply plugged. The embedded vision kit contains a VC-MIPI camera module including software driver, an FPC-VC-MIPI cable (flexible circuit board) and an S-mount/M12 lens holder. The trigger functionality required for industrial vision applications is also already provided.
As standard, the bundle is equipped with the OV9281 image sensor from OmniVision with a resolution of 1 MP, 120 fps frame rate and global shutter. Alternatively, the entire range of VC-MIPI camera modules is available, all of which can be connected to the CMI board.
According to Vision Components, the 'VC CMI Board' offers an SD card slot for additional storage space, GigE and USB interfaces, a trigger input, a flash trigger output, digital interfaces (four inputs, four outputs), a display output and connections for two MIPI camera modules for optional stereo vision applications for maximum flexibility in OEM designs.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our weekly newsletter and keep your finger on the pulse of automation time. Once a week, on Tuesdays, we provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products. Stay up to date with us.
Our newsletters are of course free of charge and can be canceled at any time!
Click here to register.
Vision & Control
Optimized for blue light
Within the visible spectrum, monochromatic image examinations with blue light are the most effective. The lenses in the Blue Vision series from Vision & Control are specially designed for this spectral range.
Vision Components
In mini format
Vision Components has developed a complete embedded vision system that is barely larger than an image sensor module. PicoSmart System is suitable for the development of compact vision sensors.
InoNet
Developed for 24/7 operation
The Concepion-hX, a fanless embedded PC from Inonet, with 10th generation Intel Core i CPUs, is a system developed for 24/7 operation and works at ambient temperatures from -10 to +55 °C.
Cognex
Highly sensitive wafers moved safely
Until now, the transport of wafers from one workstation to the next with the help of robots has been hampered by the lack of precision with which mobile robots move and grip. A solution from Kuka and Cognex aims to change this.
autoVimation
Precisely align the protective housing
The positioning system is a compact solution for the precise alignment of protective camera housings. The core of the modular system consists of fine positioning axes with 150 mm stroke, which ensure high adjustment accuracy with their hand-cranked...
