IOSS
Code reader based on AI
The intelligent code readers of the DMR4XX line from IOSS automatically adapt their reading strategy by continuously improving themselves during the process: the more codes are read, the more strategies the integrated software generates or optimizes.
Code readers from the DMR4XX line from IOSS
© IOSS
This makes the system insensitive to possible process fluctuations, eliminating the need for constant adjustment. The automatic optimization of the reading process results in high process reliability, even in difficult environments. The readers use IOSS' owndecoding algorithms for all marking processes. They can be easily adapted to individual requirements, and various interfaces such as Profinet facilitate integration into systems.
The devices are available in various technical versions - different sensor resolutions, lenses and illumination colors are available. The reading systems can be used for all data matrix codes in industrial sectors, including automotive, semiconductors, logistics and automation.
Cognex
Access to IIoT data
The Cognex Edge Intelligence (EI) platform from Cognex helps monitor barcode reader performance and device management to reduce downtime and increase productivity in manufacturing and logistics processes.
Compar
Artificial intelligence for image analysis
For soldered connections on printed circuit boards, the switch to lead-free solder causes increased failure rates. Quality control must therefore be improved. However, conventional methods with camera-supported automatic image evaluation quickly...
Proglove
Modern work assistance
Demographic change poses enormous challenges for industry and logistics, because while the shortage of skilled workers is increasing, people remain irreplaceable in many processes. This is where wearable assistants come into play, providing...
