Micro-Epsilon
Automated empties inspection
In contrast to conventional image processing systems, modern laser scanners not only check the completeness of the empties - they also determine whether the correct bottle type is in the crate.
© Micro-Epsilon
Beer bottles that come to the customer from the bottling plant or brewery usually make their way back again. After all, glass bottles are returnable bottles that can be refilled 40 to 50 times. Millions of bottles arrive at the individual breweries or bottling plants to be refilled. To ensure that the machine processing steps - such as removing the caps and labels, washing and refilling - run smoothly, it is essential to carefully check the crates directly on receipt of the goods.
On the one hand, completeness plays a major role here, and on the other, it is important to ensure that the correct bottle types are in the corresponding crates. Breweries have to deal with different types of bottles: The brewery's logo is often embedded in the glass or the bottles have been produced in a specific shape that only a certain manufacturer sells. It is estimated that every third bottle is delivered to the breweries incorrectly. As the crates are often checked manually by employees, this requires more staff. This manual inspection is also a strenuous and error-prone process. The crates run along the conveyor belt, which requires a lot of concentration from the employee. If this concentration wanes, often not all faulty bottles are detected or bottles are missing from the crates despite being checked. Laser scanners, for example from Micro-Epsilon, are a more efficient and reliable inspection method.
Automated processes
The Slovenian company Tipteh has developed an inspection system with laser line triangulators for the fast and fully automated inspection of empties, which is already being used to inspect incoming crates. This inline construction is equipped with five laser scanners from Micro-Epsilon 's 'Scancontrol 2900-50' series.
Five laser scanners from the 'Scancontrol 2900-50' series inspect the beverage crates on a conveyor belt from above in the production line. Each scanner measures a row of bottles in the crate.
© Micro-Epsilon
In the production line, the scanners measure from above onto the beverage crates, which are guided on a conveyor belt. Each scanner measures a row of bottles in the crate. The presence check is carried out at throughput speeds of up to 850 mm/s. In contrast to a solution with conventional image processing systems, the laser scanners not only check the presence of the bottles, but also their height. The sensor uses the respective bottle height to determine whether the correct bottle type is in the crate. In this application, the height of the bottles must not deviate by more than 3 mm from the target height of the respective type.
The result of the evaluation as 'OK' or 'not OK' is received by the PLC so that faulty crates can be ejected directly. For the user, the measurement results can also be displayed on an integrated screen on the control unit.
The Slovenian company Tipteh has developed an inspection system with laser line triangulators for the fully automated inspection of empties, which is already being used to inspect incoming crates.
© Micro-Epsilon
With up to 2000 measured values per second, the sensor is suitable for both static and dynamic processes. The main challenge with this measurement task lies in the different reflection properties of the bottles, which vary due to the different glass colors.
The challenge of color and movement
Compared to a solution with conventional image processing systems, the laser scanners not only check the presence of the bottles, but also their height.
© Micro-Epsilon
These are mainly shades of green and brown. To make matters worse, there are bottles with or without lids in the crate at goods inwards. The scanner recognizes this using stored algorithms. Shocks caused by transportation on the conveyor belt also mean that the bottles are exposed to constant vibrations. Thanks to the special measuring principle, the laser scanners are insensitive to these challenges: they use the triangulation principle for two-dimensional profile detection. This means that the scanner emits a laser beam that is expanded into a laser line. This hits the object to be measured. The laser light is reflected by the surface of the measurement object and imaged on a highly sensitive receiver matrix in the sensor.
Christian Kämmerer is Head of Sales 2D/3D Optical Metrology at Micro-Epsilon Messtechnik in Ortenburg.
© Micro-Epsilon
From this matrix image, the controller calculates the position along the laser line (x-axis) in addition to the distance information (z-axis). These measured values are then output in a sensor-fixed, two-dimensional coordinate system . In the case of moving objects or when the sensor is traversed, 3D measurement values can also be determined.
The laser scanners can be positioned at a great distance from the measurement object and record 1280 measurement points per profile via the laser line. The measured values are evaluated directly in the production line. The raw data is integrated into image processing software and evaluated via a GigE Vision connection. The data can also be logged for subsequent statistics, evaluations or process optimization.
SVS-Vistek
Machine Vision streamlined
In order to generate the required amount of light for high-quality images, image processing systems usually work with external flash controllers. A current approach integrates these control units into the camera, thus reducing effort and costs for...
Siemens
The new products
This year's innovations from Siemens include the Sitrans MS Multisensor, which is used primarily for monitoring the condition of mechanical system components such as pumps, compressors, gearboxes and valves.
Embedded Vision
On the advance
Falling prices and rising performance - the perfect basis for embedded vision technology. Six experts discussed this and more during Embedded World 2020 at the panel discussion 'Embedded Vision everywhere? ' organized by the VDMA Machine Vision...
