Sick
3D image quality for high-speed applications
Sick launches the 'Ruler3020', the first 3D streaming camera of the new generation 'Sick Ruler3000'.
The 'Ruler3000' 3D streaming camera with class 2 laser, pre-selected optics and fixed geometries for defined fields of view from Sick.
© Sick
The 'Ruler3000' product family combines Sick 's 'Ranger3 Streaming' camera with an eye-safe class 2 laser, pre-selected optics and fixed geometries for defined fields of view. With Sick's highly sensitive CMOS sensor and ROCC (Rapid On-Chip Calculation) technology, the 'Ruler3000' 3D streaming cameras scan and process up to 15.4 Gp/s, enabling up to 7000 three-dimensional full-frame profiles per second. This makes the 3D vision solutions in the product family particularly suitable for high production and process speeds. The cameras extract the 3D shape of an object regardless of its contrast or color. At the same time, the sensor performs greyscale and scattered light measurements, which further optimize the results of image processing and measurement accuracy. The high light sensitivity enables the precise inspection of even very dark or highly reflective materials. Thanks to the HDR (High Dynamic Range) function, even components with very different light emissions, such as tires and shiny metal assemblies, can be reliably captured in a single scan.
The integration of the camera is simplified by the stream setup interface. The company's 'GenIStream API' facilitates integration for C# and C++ programmers. Full compatibility with industry standards such as GigEvision and GenICam enables plug-and-play access to third-party software such as Halcon and Labview. In addition, developers have the flexibility of the 'AppSpace' software development platform with its wide range of image processing tools and application examples.
The 'Ruler3020' is the first camera in the product family. It delivers 3D profiles with up to 7 kHz in full format or up to 46 kHz with a reduced measurement window. The measured values are output in millimeter values with a Z-resolution of 8 µm to 15 µm and an X-resolution of 63 µm to 88 µm. Sick plans to launch further variants with different fields of view on the market in the course of 2021. With its compact design, the camera with IP65 and IP67 protection can also cope with harsh industrial environments without the need to construct expensive protection in the machine.
Sick
Paving the way for digitization
'We Create Digital Transformation' was Sick's trade fair motto to present intelligent sensors as pioneers of digitalization as well as digital services and software solutions based on their data.
Sick
Works in confined spaces
With the InspectorP61x, Sick is launching a compact all-in-one 2D vision sensor that enables inline vision inspections even in the tightest of spaces or mounted on robots.
Sick
Scans an area of up to 200 m²
With the 'TiM2xx' product family, Sick is expanding its range to include 2D LiDAR sensors for localization and anti-collision applications. The TiM240 is the first variant in the series and complies with protection class IP65 for indoor use.
