Schunk
Targeted preselection of the right system
With the intelligent calculation and design tool Gripping, Schunk simplifies and accelerates the engineering of handling systems.
© Schunk
A few details about the gripper type, workpiece and gripping situation are all it takes for the system to select the appropriate modules from the supplier's standard gripping component program.
from the supplier's standard range of gripping components. In addition to the corresponding gripper
The hit list includes technical information, drawings, images and details of the respective degree and reason for utilization in addition to the corresponding gripper types. The tool can be used to maximize the performance of the individual grippers and avoid costly oversizing.
According to Schunk, the calculation and design process is also significantly accelerated. Intelligent logarithms enable a targeted preselection, which also takes into account components that the designer and system planner may not have on hand.
Both the hit list and the individual details can be saved, which enables complete documentation and archiving of the design as well as recalculation in the event of changed details. The data can also be called up again at any time for subsequent projects. The intuitive, HTML-based tool takes around 2550 grippers into account.
Schunk
The smart gripper
Condition monitoring systems (CMS) detect changes and anomalies in the production process. Due to their position 'closest-to-the-part', gripping systems and clamping devices are rapidly gaining in importance in this context.
Fruitcore
A robot called Horst
The aim when developing Horst was to create a robot solution that is simple both mechanically and in terms of software and that is specially tailored to the needs of small and medium-sized companies. What is behind this?
Three questions for ...
Trends in robotics
Under the title "Three questions for ...", computer-automation.de is publishing short interviews with the leading figures in the automation industry on a regular basis this year. This month, the focus is on robotics.
