Pulse
For marine applications
The 24 V, 20 A top-hat rail power supply CP20.245-R2 from Puls was developed for onshore and offshore use in the shipping and process industries.
© Pulse
The marine-compliant power supply meets the requirements of EMC class B without external filters and can be used directly on the bridge and on deck. The power supply unit offers high immunity to transients and voltage peaks as well as a robust aluminum housing. It provides the full output power of 480 W even at fluctuating ambient temperatures between -40 and +60 °C.
Puls 's comprehensive approval package includes Marine DNV, Marine ABS and ATEX. An integrated decoupling MOSFET enables safe 1+1 and n+1 redundancy between the power supplies, which ensures the availability of all necessary systems in the event of a fault. The 'CP20.245-R2' is based on the industrial version of the 'CP20', with an efficiency of 95.2 %. The power reserve of 20 % has also been adopted from the basic version.
MTM Power
For 'on machine' applications
The AC/DC modules of the PM-IP67A series with AC and DC wide-range input from MTM Power with protection class IP67 enable simple and fast 'plug and play' supply of control components without cost-intensive control cabinet solutions, even in...
Tsubaki cable towing
Minimized abrasion
In the gliding operation of cable drag chains, abrasion in gliding operation as well as oscillations and vibrations are part of the status quo. A module mounted on the carrier provides a remedy by quickly and controllably placing the upper run on...
Michael Koch
Reduce peak loads
Active energy management systems between drive and storage regulate the energy balance of drive systems, whether for a single drive or for several axes in a DC link system. A plug-on module also enables peak load reduction via Plug&Play.
