ipf electronic at the SPS 2024
Compact multi-color LED signal light
© ipf electronic
With the 'EZ650520', ipf electronic presents a flat multi-color LED signal light with a height of just 25 mm.
Thanks to its 360° design and large aperture angle, the round luminaire with a diameter of 65 mm is highly visible from all sides when in use. The housing (protection class IP67) is made of aluminum and the front panel is made of robust acrylic glass with diffuse scattering characteristics. The selectable signal colors red, green and blue are preset at the factory. The colors magenta, orange, yellow or white can also be generated by connecting additional pins. The ipf light is designed for an operating voltage of 22 to 28 V(DC) and for ambient temperatures of -20 to +40 °C. The LED signal light is attached with two screws on the back.
Hall 7A, Stand 131
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Captron
New brand presented
With the new 'Captron Solutions' brand, the sensor manufacturer is presenting itself as a total solution provider that serves the market with process consulting and software development services in addition to its traditional hardware business.
